Home > Technical (L405) > L405 rear diff and oil leak help
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Hi all , just had my 15 4.4 ab oil changed and indie has pointed out weeping rear diff and some oil leaking on the left hand turbo ( RHD FFRR). Its hnder warranty but i prefer to have indie do any work. I have seen the diff weep is common enough and there is a parts kit for the repair but would anyone know what tools are needed as indie has not done this on an FF before ( hes a BMW specialist) he advises that a unique tool is needed to loose a particular nut , any ideas please.
On the oil leak , its not using any oil and the engine is completely dry above the turbo , again any ideas or common problems in this area.
Thanks in advance 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #524773 14th Aug 2019 1:32pm
CS
There are some other recent threads on these topics. Re the turbo oil leak, my 2012 WM had a slight leak from a turbo, it was pre-turbo drain mod, not sure if yours would be. The dealer advised monitoring, it seemed not to get worse and the car worked fine until I sold it. That was maybe eighteen months. So maybe clarify if yours is bad enough to need work yet.
Getting the revs above 2,500 seemed to be regarded as a good thing for stopping build-up of oil in the second turbo. Only Range Rovers since 1988
Post #524783 14th Aug 2019 2:34pm
dolph34
Many thanks CS, i don't think the drain mod is an issue with my year but i will google it. Thanks again 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #524791 14th Aug 2019 3:13pm
