Home > Technical (L322) > charging battery - electrical expert required..!
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Kids left an interior light with the result now being a dead battery... Rolling Eyes The range rover is down the side of the house so unless i push out i cant get jump leads to it, dont need it for a few days so i have disconnected the battery and put my charger on it.
Now that is the question; my charger is old and tiny! its got 12v 6 amps written on it so is this up to the job of charging a range rovers battery, if so how long will it take, or do i need to go buy a new one? 2004 black Vogue TD6
Post #52520 2nd Mar 2011 1:56pm
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
to be honest take the battery to your local independent battery supplier and get them to put on a proper controlled charge
probably £5 to the guy!
they will also do a battery 'condition' test for you FOC - this is done on a computer controlled 'machine' and gives a percentage efficiency result
Post #52521 2nd Mar 2011 2:00pm
should be ok but it'll take about 24 hours to charge up... ... - .- -.
Post #52525 2nd Mar 2011 2:03pm
Do you have Tow Bar electrics?
Post #52526 2nd Mar 2011 2:04pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
I may be wrong but I'm sure when my kids have left the lights switched on that they shut off anyway when the cars systems shut down.. I guess this assumes the car was locked. Though I may be wrong Confused 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #52527 2nd Mar 2011 2:06pm
nick h
Gaz - does this make a difference as i have tow bar electrics?
Post #52528 2nd Mar 2011 2:06pm
I believe you may be able to connect a booster battery via the tow electrics but not certain.....
Certainly do not try this until somebody verifies it can be done Exclamation
Post #52531 2nd Mar 2011 2:11pm
dan_uk_1984
12 +/- feed there - I have thought about this for a charging point too...
But anyhoo, I have a similar charger. If the battery isn't completely flat then 30 mins - 1hr is fine I found. I had to to this when I left the interior light on, it is possible to override the time-out function - Doh!
If the battery is completely flat you will have damaged the plates and now it won't take as much charge again, maybe look at replacing it next winter as long as you don't start getting gremlins.
D
Post #52533 2nd Mar 2011 2:15pm
letsavit2
You may well be correct, as although i'm blaming the kids (got to have someone to shout at.. Laughing ) i did not lock the car, also rear door was left slightly open... Rolling Eyes
Still the kids fault as chances are they where arguing so i forget to go back and check lock the range rover... Laughing 2004 black Vogue TD6
Post #52535 2nd Mar 2011 2:22pm
Pretty sure its a good charging point but not sure about a booster battery jump due to cable size back to battery?
Post #52536 2nd Mar 2011 2:23pm
letsavit2
D
Yes Gaz i do have tow bar electrics
I do need to think about setting up a trickle charge of some sort. Sometimes i dont use the range rover for a week, then it might get started for a short journey.
I'm thinking solar? 2004 black Vogue TD6
Post #52537 2nd Mar 2011 2:27pm
a very low amps for a duration would be ok as is the same with these things that plug into your ciggy lighter ..a proper jump start will only work via the terminals under the bonnet.. ... - .- -.
Post #52538 2nd Mar 2011 2:28pm
letsavit2
thanks for the replies guys.... Wink
the charger has 4 lights on it, 1amp-2amp-4amp-6amp. all 4 are on, am i correct in thinking 6 then 4 etc will go out to indicate the battery is charging.
sorry for the dumb questions, electrics are not my thing.. Embarassed
also got the "air suspension inactive message" when trying to start this morning so might have to do the steering wheel left to right thing when\if she starts. 2004 black Vogue TD6
Post #52556 2nd Mar 2011 3:43pm
letsavit2
she started and the left to right on the wheel has cleared message..... Thumbs Up 2004 black Vogue TD6
Post #52592 2nd Mar 2011 6:59pm
Vogue
a very rough rule of thumb is :-
if its a 6 amp/hr charger and say a 110amp battery, just divide the 110 by 6 = 18 hours required to charge the battery, then just add a couple of hours for lost amps in the charging process = say 20 hours to fully charge. This is assuming there is no drain on the battery from other sources.
Post #52615 2nd Mar 2011 10:45pm
