![]() | Home > Technical (L322) > charging battery - electrical expert required..! |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
to be honest take the battery to your local independent battery supplier and get them to put on a proper controlled charge
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
should be ok but it'll take about 24 hours to charge up... ... - .- -.
Do you have Tow Bar electrics? |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
I may be wrong but I'm sure when my kids have left the lights switched on that they shut off anyway when the cars systems shut down.. I guess this assumes the car was locked. Though I may be wrong |
Gaz - does this make a difference as i have tow bar electrics? |
I believe you may be able to connect a booster battery via the tow electrics but not certain.....
12 +/- feed there - I have thought about this for a charging point too... But anyhoo, I have a similar charger. If the battery isn't completely flat then 30 mins - 1hr is fine I found. I had to to this when I left the interior light on, it is possible to override the time-out function - Doh! If the battery is completely flat you will have damaged the plates and now it won't take as much charge again, maybe look at replacing it next winter as long as you don't start getting gremlins. D ![]() |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
You may well be correct, as although i'm blaming the kids (got to have someone to shout at.. ![]() ![]() Still the kids fault as chances are they where arguing so i forget to go back and check lock the range rover... ![]() |
Pretty sure its a good charging point but not sure about a booster battery jump due to cable size back to battery? |
Yes Gaz i do have tow bar electrics I do need to think about setting up a trickle charge of some sort. Sometimes i dont use the range rover for a week, then it might get started for a short journey. I'm thinking solar? 2004 black Vogue TD6 |
a very low amps for a duration would be ok as is the same with these things that plug into your ciggy lighter ..a proper jump start will only work via the terminals under the bonnet.. ... - .- -.
thanks for the replies guys.... |
she started and the left to right on the wheel has cleared message..... |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
a very rough rule of thumb is :-
