Home > Technical (L405) > Cooled seat question.
Statler
United Kingdom 2016 Range Rover Autobiography SDV8 Aleutian Silver
Morning,
How much air should we expect from the cooled front seats? mine doesn't seem to change with either of the 3 settings of whatever i set the climate to!
Does anybody have any advice please?
Thanks
Post #525047 16th Aug 2019 12:46pm
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
Interested in this too as have been underwhelmed by my L405's cooled seats after coming from the L322. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #525051 16th Aug 2019 1:38pm
Statler
Mines a 2017 also, as you say very underwhelming and there appears to be just one effect from the 3 settings!
Post #525055 16th Aug 2019 2:01pm
put a feather or something else which is very light onto the seat and go through the settings...you should get an idea if setting 1 is the same as setting 3... ... - .- -.
Post #525058 16th Aug 2019 2:20pm
GGDR
To Stan's point, I learnt a few years back of a builder the best way to test extractor fans:
A tissue.
It's a great way of 'seeing' air flow. On the cooled seats, I'd go single ply.
. Cheers, Greg
Post #525082 16th Aug 2019 6:24pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
I too have been underwhelmed by the cooled seats in the 405 compared to the 322. I’ll try the tissue test.
Post #525136 17th Aug 2019 2:45pm
Bill
I find mine to be comfortable usually on one or two.... it’s a gentle cooling rather than a blast , better on a long journey Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #525213 18th Aug 2019 10:43am
Badger
United Kingdom 2018 Range Rover Autobiography 2.0 PHEV Carpathian Grey
Are you running the a/c on LOW?
Not only should you be very aware of the feeling of cool air coming through the perforated seat leather, but you should also be able to hear the fans.
Post #525541 20th Aug 2019 3:28pm
pherplexed
United States
I can hear the fans on my seats, but agree with the others that the 'cooling' sensation is practically nonexistent on the max setting. The cabin AC works great - ice cold.
I assumed the cooled seats got their cooled air supply from the main cabin AC and that a fan on the seat just helped circulate it. Is that the case or do the seats have their own little cooler unit (like the one used in the center console cooler box?) 2021 P525 | Eiger Gray
Post #525547 20th Aug 2019 4:04pm
United Kingdom 2017 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
I believe the air is cooler if you have the AC on and just normal outside (cold) air if you don't. 1994 Range Rover LSE Autobiography
1994 Range Rover Vogue LSE Softdash
1994 Range Rover Vogue LSE (transmission failed so now a donor car!)
1994 Range Rover Vogue LSE (knackered donor car!)
1993 Range Rover Vogue LSE
1969 Aston Martin DB6 Vantage
1953 Lagonda DB3.0 Drophead Brooklands
1939 Lagonda LG6
Post #525729 21st Aug 2019 5:31pm
