![]() | Home > Technical (L405) > Charging Auxiliary Battery |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
Will it not get charged once the vehicle is started from the main battery? Current: RR L322 2010
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8008 ![]() ![]() ![]() |
I'm not sure how they connect - will need to have a play with a meter on them.
Yes a voltage sensing relay (VSR).
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35681 ![]() ![]() |
the aux battery is for the stop/start, if you dont like that feature then disconnect it or leave it flat.. ... - .- -.
It must do more than stop/start - I don't have that feature on mine, but I have an auxiliary battery..... |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 718 ![]() ![]() |
If it just did stop/start I would happily disconnect it but I think it does more.
connecting directly will probably cause problems with the BMS [battery monitoring system]
Also you shouldn't charge a battery in a vehicle (esp in the passenger compartment).
I don't know its flat for sure but I know the main battery is fine because it is on the CTEK and the car starts fine and everything seems to be OK. However I get a battery warning on the dash. Also the tailgate does not operate automatically. If I drive it long enough all these things go away so I thought it might be the aux battery going flat once the car has been left for a couple of months even though the main battery is on the charger. |
And you are charging it as an AGM battery on the ctek? Current: RR L322 2010
I don't know for sure. I just have the car icon selected on the options. |
Just got the instructions out. No. I am not using the AGM option. Should I be doing this? |
Assuming they are all AGM batteries so would have thought so. Current: RR L322 2010
I charged it using the higher voltage setting and that seems to have done the trick.
