Home > Technical (L405) > Charging Auxiliary Battery |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 201 |
Will it not get charged once the vehicle is started from the main battery? Current: RR L322 2010
21st Aug 2019 11:43am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7762 |
I'm not sure how they connect - will need to have a play with a meter on them.
21st Aug 2019 11:55am |
Yes a voltage sensing relay (VSR).
21st Aug 2019 12:02pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34922 |
the aux battery is for the stop/start, if you dont like that feature then disconnect it or leave it flat.. ... - .- -.
21st Aug 2019 12:45pm |
It must do more than stop/start - I don't have that feature on mine, but I have an auxiliary battery..... |
21st Aug 2019 1:38pm |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 709 |
If it just did stop/start I would happily disconnect it but I think it does more.
21st Aug 2019 1:58pm |
connecting directly will probably cause problems with the BMS [battery monitoring system]
21st Aug 2019 2:11pm |
Also you shouldn't charge a battery in a vehicle (esp in the passenger compartment).
21st Aug 2019 3:08pm |
I don't know its flat for sure but I know the main battery is fine because it is on the CTEK and the car starts fine and everything seems to be OK. However I get a battery warning on the dash. Also the tailgate does not operate automatically. If I drive it long enough all these things go away so I thought it might be the aux battery going flat once the car has been left for a couple of months even though the main battery is on the charger. |
21st Aug 2019 3:34pm |
And you are charging it as an AGM battery on the ctek? Current: RR L322 2010
21st Aug 2019 3:43pm |
I don't know for sure. I just have the car icon selected on the options. |
21st Aug 2019 4:22pm |
Just got the instructions out. No. I am not using the AGM option. Should I be doing this? |
21st Aug 2019 4:28pm |
Assuming they are all AGM batteries so would have thought so. Current: RR L322 2010
22nd Aug 2019 11:58am |
I charged it using the higher voltage setting and that seems to have done the trick.
23rd Aug 2019 7:27am |
