Home > Maintenance & Mods (L405) > running wire from cab to engine bay
as above , any thoughts on how to do this? ... - .- -.
Post #526144 26th Aug 2019 11:38am
How brave are you feeling ?
I'd likely run it passenger side, over the back top rear (just under the bonnet) and down by the door hinges, then through there - either where the cables to the door already go, or drill a new hole, or see if you could tape it up out of the way - then through around the rear of the lower glove box.
Post #526145 26th Aug 2019 11:47am
i'm pretty brave Alistair Mr. Green
so not exactly via the bulkhead then? not thought of doing it that way.. Thumbs Up ... - .- -.
Post #526147 26th Aug 2019 11:52am
Bulkhead looked pretty inaccessible to me
Post #526153 26th Aug 2019 12:52pm
agreed...theres to much stuff in the way.... ... - .- -.
Post #526156 26th Aug 2019 1:19pm
Baltic Blue
Does the air box for the pollen filter come out easily, in a similar way to the L322 ?…… it might reveal an existing grommet hole ?
Post #526157 26th Aug 2019 1:26pm
not sure Mike...that would bring it out around the top or behind the head unit.. ... - .- -.
Post #526158 26th Aug 2019 1:37pm
If what you are wiring is only for the duration of you owning the car it's usually possible to get the cable to the front passenger door opening from the engine bay and then tape the cable to the body above the top hinge, lift the inner door seal and run the cable over the seal mounting flange and into the car that way.
I would suggest a couple of layers of gorilla tape or similar over the flange and then tape the cable in position before fitting the door seal back in place.
Did this to my own car a few years ago and never had any bother to date.
The cable/tape can only be seen when the passenger door is open and looks quite neat, saves a lot of work.
Post #526162 26th Aug 2019 1:59pm
i think thats the same as Alistair's suggestion ..i reckon that will be the best way to do this, thanks.. ... - .- -.
Post #526163 26th Aug 2019 2:04pm
p38arover
Australia
Does the L405 differ from the L322 insomuch as access from the engine bay?
On my L322, I ran power and coax from my UHF radio through the grommet behind the battery. I removed the battery, then slip some stiffish wire (brazing rod or 16 gauge steel welding rod, if I recall correctly) through the grommet. I attached the 12V wiring to that and pulled it through, leaving a fair bit of slack. Then I attached the coax to the 12V wiring and continued pulling.
Spray cleaner/Detergent on the wiring makes it slippery and easier to pull through. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #526200 27th Aug 2019 12:02am
its a lot different..the battery is in the boot for a start and there doesnt seem to be any obvious route's into the cabin... ... - .- -.
Post #526206 27th Aug 2019 8:12am
p38arover
Australia
Thanks Stan Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #526231 27th Aug 2019 1:25pm
thanks for all your suggestions, i've gone the door pillar/trim route....dont look to bad Thumbs Up ... - .- -.
Post #526341 28th Aug 2019 1:18pm
Hard to give you marks out of 10 without the photos...... Whistle
Post #526366 28th Aug 2019 5:45pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
What about near the steering wheel connection into the cabin it seems to run through a rubber boot through the bulkhead you might be able to squeeze it through that way !
Post #526408 29th Aug 2019 7:41am
