![]() | Home > Maintenance & Mods (L322) > Driveshaft popped out of front diff? |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2263 ![]() ![]() ![]() |
Just an update to this It’s happened again!
IMHO, there has to be some major problem with the front suspension joints to allow the hub to move away from the diff sufficiently to disengage the splines. No front suspension system is designed to allow that under normal conditions. The shafts are basically floating in a space smaller than their length.
The cv joint had recently been replaced - any chance they could not have quite put it back together right and now Its back in it could be ok? Current stable:
its me Member Since: 08 Mar 2013 Location: southampton Posts: 78 ![]() ![]() ![]() |
There is every chance that they didn't get it fully infor the ring to locate but this also happened to me on a 4.2. See a post of mine about it. In my case the locking ring was broken in two and no work had been done on it previously. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
Thanks - I have messaged the garage it’s at to check that they say it all looks in ok but I’ll get them to confirm the clip Current stable:
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
They might have used the old clip. I did on mine and it pulled out after a week or so. New clip and never happened again.
Ok bard on this I have booked it into the Indy next week to strip back and replace the clip and anything else that looks not quite right... will keep you posted Current stable:
