![]() | Home > In Car Electronics (L322) > L322 touchscreen sat nav error |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Have you got a photo of the disc? Current: 2011 FFRR Vogue SE 4.4 TDV8
JonnyO Member Since: 01 Sep 2019 Location: Loughborough Posts: 28 ![]() ![]() ![]() |
Should be able to get one in a few days |
I suspect exactly as it says -- wrong disc, or corrupted disc, dare I suggest non original? Current: 2011 FFRR Vogue SE 4.4 TDV8
Well, it’s an original disc. I got it out once. Put it back in again. Now it won’t eject. Should I suspect the drive do you think? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
I had similar, the disc not ejecting. The GPS was throwing up errors too. It was down to a problem with the pins on the plug to the drive. As a first step take it out and check the pins for integrity and also for verdigris. Mine were quite heavily corroded.
Pulled the unit out and no pin damage or corrosion. Also got the disk to eject. May try replacing the disk first and crossing my fingers. Where can I obtain a new disk? |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
IMHO.. Not worth spending considerable money on fixing an outdated poor LR satnav system, unless your a stickler for originality and needing everything having to work.
Thats probably what I'll end up doing. Might try a few quid on a new disk in case its that simple and cheap but no more than that. |
Just to close this up. After plugging and unplugging the computer module it sprung into life. |
Billie Member Since: 12 Oct 2020 Location: south-west Posts: 49 ![]() ![]() ![]() |
I know this is a couple of months old but can I ask what disc you are using. I have the DVD-ROM from Japan, for Land Rover dated 2005 but underneath it states : 1993-2004 NAVTEK. When I insert the disc the screen states "wrong disc"
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
You have the same car as mine so this is what I purchased
Ooops, sorry didn't mean to cause any hassel |
