Home > In Car Electronics (L322) > L322 touchscreen sat nav error
JonnyO
United Kingdom 2004 Range Rover Vogue 4.4 V8 Stornoway Grey
Getting the error on the attached photo when I press the sat nav button on the 2004 l322 that has the touchscreen sat nav unit that I have just bought. Does anyone know what is the likely culprit for this and how I might go about fixing it?
Really appreciate any help as I'm a total newbie!
Post #527027 4th Sep 2019 12:10pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Have you got a photo of the disc? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #527028 4th Sep 2019 12:16pm
JonnyO
Should be able to get one in a few days
Post #527029 4th Sep 2019 12:51pm
Bushy30
I suspect exactly as it says -- wrong disc, or corrupted disc, dare I suggest non original? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #527032 4th Sep 2019 1:06pm
JonnyO
Well, it’s an original disc. I got it out once. Put it back in again. Now it won’t eject. Should I suspect the drive do you think?
Post #527330 7th Sep 2019 6:17pm
Weegie
I had similar, the disc not ejecting. The GPS was throwing up errors too. It was down to a problem with the pins on the plug to the drive. As a first step take it out and check the pins for integrity and also for verdigris. Mine were quite heavily corroded.
If that doesn't do it there is a guy, in the Birminham area as I remember, who advertises on the Bay of Es. I sent my unit to him - the pins had got damaged - and he sorted it out. It's a couple of years ago now and I can't recall his name. Try a search and also if I can find it I will let you know. John
GAP iiD BT-Sold
Post #527331 7th Sep 2019 6:35pm
JonnyO
Pulled the unit out and no pin damage or corrosion. Also got the disk to eject. May try replacing the disk first and crossing my fingers. Where can I obtain a new disk?
Post #527393 8th Sep 2019 7:52pm
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
IMHO.. Not worth spending considerable money on fixing an outdated poor LR satnav system, unless your a stickler for originality and needing everything having to work.
Personally I use, my smart phone on a magnetic mount above the car screen, using several inexpensive but ALWAYS current sat nav apps that Bluetooth voice instructions through cars speakers. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #527450 9th Sep 2019 12:49pm
JonnyO
Thats probably what I'll end up doing. Might try a few quid on a new disk in case its that simple and cheap but no more than that.
Post #527460 9th Sep 2019 2:10pm
JonnyO
Just to close this up. After plugging and unplugging the computer module it sprung into life.
Post #564849 17th Aug 2020 9:41pm
Billie
England 2006 Range Rover Vogue 4.2 SC V8 Buckingham Blue
DVD ROM
I know this is a couple of months old but can I ask what disc you are using. I have the DVD-ROM from Japan, for Land Rover dated 2005 but underneath it states : 1993-2004 NAVTEK. When I insert the disc the screen states "wrong disc"
Are you required to purchase from a dealer? Would really like this system to work, even if it's a couple of years out of date...B
Post #571129 28th Oct 2020 1:06pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
You have the same car as mine so this is what I purchased
This post has been edited by the site administration team-link deleted due to the sales of illegal nav discs.
Works for me and only £25
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #571134 28th Oct 2020 2:00pm
Billie
Ooops, sorry didn't mean to cause any hassel Rolling Eyes
Post #571306 30th Oct 2020 7:42am
