Home > Maintenance & Mods (L322) > Service Time!
sniper
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Causeway Grey
Just done the air filters and the Pollen, easy peasey thx..! just the fuel and oil left to do later this week im sure they will be much less fun Sad im assuming the right hand air box will need to be removed again to gain enough access to get to the fuel filter? (tho a post i found on here that says its takes only 6 mins didnt say that you need to?)
IN ADDTION... is there an easy way to reset the service timer message? with ignition/button presses and pedal pushes etc?
Thx
Post #527058 4th Sep 2019 5:10pm
Baltic Blue
I have only changed the fuel filter on mine once, .... it was very tight, particularly the water trap, but I managed it eventually with a few grazed knuckles.
I intend to remove the airbox next time , hoping it will make the job easier... I don’t mind if it takes longer , ..
It won’t be this year, but I will report back when done.
Mike.
PS I use an iid to reset the service indicator. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #527060 4th Sep 2019 5:26pm
sniper
i dont know what an IID is, a bit of googling didnt help much... i was hoping to avoid a "tool" and wondered if there was a way like my Defender where you hold brake and accel, when turing on ignition for x seconds etc..
Post #527083 4th Sep 2019 7:04pm
DrRob
You’ll need an IID Bluetooth to reset the service interval on your vehicle. It’s needed as the oil engine life is calculated in the ECU. Also it will come in very handy for fault diagnosis, altering settings etc etc.Second hand units come up on here or sister sites occasionally and the £25 to change VIN ownership. Or buy new from Dan off here for £405. It will pay for itself in long run and holds its value if you ever need to sell it. Don’t look at anything else. App driven too Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #527089 4th Sep 2019 7:16pm
DrRob
https://www.fullfatrr.com/forum/topic47809.html 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #527090 4th Sep 2019 7:17pm
sniper
£400 to reset the service timer? surley not? WTH?
Just did my Defender, ignition on, brake and accel for 15 seconds, oil light flashed, turn off ignition, DONE!
is this really the only way to spend £400 on a tool? <shakes>
Post #527091 4th Sep 2019 7:37pm
DrRob
It needs a diagnostic to do it. No other way in your model year. There are cheaper ones around e.g icadsoft LR2 which I think can do it but check. The investment is worth it as the IID does a lot, lot more than anything else out there. Peace of mind to have it in the glove box. Or get an independent service place to do it once you've changed the oil 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #527093 4th Sep 2019 7:54pm
sniper
Gosh, ok thx...
Post #527094 4th Sep 2019 7:55pm
WB
The IID tool is great but you can reset your service lights using the much cheaper and still very useful iCarsoft - available on amazon they make a few versions which are around the £95-£130. It does all the fault code reading and resets as well as most of the live values. A good budget alternative to an IID.
Post #527190 5th Sep 2019 11:08pm
DrRob
I’ve had both and wish I’d just saved a bit longer and got an IID in the first place . Sold the icarsoft to a work mate eventually Whistle 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #527198 6th Sep 2019 7:58am
WB
I had the icarsoft before I bought the IID. In my view the icarsoft is just as useful for diagnostics (I had the v2) and a bit of a bargain. Yes you can do more with the IID but in reality beyond switching on DRLs and changing door lock settings (which LR should have just put in the car menus) I doubt most people actually make changes on a regular basis. For diagnostic purposes the icarsoft and IID are about the same.
I bought the IID used and expect I’ll be able to sell it for close to what I paid for it but I agree with the OP that it’s expensive for what it is and wouldn’t pay the new price.
Post #527202 6th Sep 2019 8:33am
Baltic Blue
Adding the numeric (digital) 2nd speedometer is my favourite change that you can do with the iid.
Post #527204 6th Sep 2019 8:48am
