Home > Technical (L322) > Splutter, jerk, judder restricted performance mystery SOLVED
Page 4 of 5 <12345>
nino_nino
some nice pictures for you Greg, this is right side of the car. it is in front of the starter and above and behind half shaft.easi to get to it. to check the operation have somebody give contact while you watch. if it moves it is ok.
Nino, 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #528047 15th Sep 2019 10:14am
GGDR
Wow Nino thank you! Is there any photo you don’t have?
When you say ‘somebody give contact’, do you mean engine running and accelerate the revs?
. Cheers, Greg
Post #528048 15th Sep 2019 10:31am
nino_nino
engine not running, when you give contact, car checks operacion of the turbo actuator. it goes up and down and makes klik / klak sound. when you learn the sound it can be heard from inside car every time you give contact. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #528051 15th Sep 2019 10:49am
GGDR
Ok thank you - but what do you mean ‘contact’?
. Cheers, Greg
Post #528052 15th Sep 2019 10:54am
Weegie
He means turn the key to the start position ie feed current to the starter. John
GAP iiD BT-Sold
Post #528053 15th Sep 2019 11:08am
nino_nino
like when you checking oil level, Greg. press starter button without pressing the brake pedal. Very Happy Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #528054 15th Sep 2019 11:11am
GGDR
Thanks John & Nino for clarifying.
Just tried that and no clicking on ignition 'contact'. But I am familiar with that click clack sound, very distinct I hear it every time I start up; in my case I hear it with the brake pedal and therefore on start up.
I used to think it was the starter solenoid (albeit loud for a starter solenoid).
I'll have another listen in a few minutes with a helper this time.
Cheers guys. Thumbs Up
. Cheers, Greg
Post #528064 15th Sep 2019 12:06pm
GGDR
Also, another question for the team:
Do I have the later type donut hoses:
I've done a search, I can see a different type in people's pictures on hoses posts but can't find a definite answer on which is the newer type.
. Cheers, Greg
Post #528067 15th Sep 2019 12:21pm
DrRob
I think you have the original weaker ones Greg.
Mine:
Clearly thick walled heavy duty type....I’m sure they are easy to make up from a length of tubing if dimensions are known... Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #528075 15th Sep 2019 1:39pm
Baltic Blue
Greg,
Yours are 100% original
Rob’s are 100 % new design.
Not wishing to gatecrash your thread,
I was out at 6.30 this AM very quick, but necessary trip to Cearneavon and back...
DPF figures... for 280 mile round trip...
Home...9.2g
wales... 11.6g
Home .... 6.6g.
I watched it all the way there and back... it never got to 14g and exhaust temp never went over 375 c... but it was up and down all day doing passive regens presumably ???
Great pictures Nino... I have never looked down there, but will be soon.
I am back in Wales Thursday , preparing for daughters wedding. next Saturday when B.B will be driving the bride to church.
Post #528088 15th Sep 2019 3:32pm
Baltic Blue
Close up picture of my replacement hose/s
Post #528091 15th Sep 2019 3:46pm
nino_nino
Greg, if there are no cracks in the ruber, no need to change. I am at 230K km and hoses look good. and I like look of the originals better/more to it then just rubber hose/. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #528095 15th Sep 2019 3:55pm
GGDR
Thanks Mike & DrRob, super helpful!
A bit of googling told me an air leak - or a vacuum leak could cause a low boost error, not just the actuator.
So at the moment it could be a bunch of things.
Cracked manifold, hoses, turbo actuator etc etc etc.
A smoke test probably best to find any leaks for both.
The CSOV is still suspect in my mind:
Nino - when you took apart your change over valve, was it faulty ?
Or just excellent Nino-style maintenance?
. Cheers, Greg
Post #528096 15th Sep 2019 3:55pm
nino_nino
I was replacing serpentine belt Greg, and it is much easier if you take valve out. i did check valve and it was ok. applied some white grees and reinstall. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #528098 15th Sep 2019 4:05pm
Baltic Blue
Greg,
https://rover.ebay.com/rover/0/0/0?mpre=ht...1121422504
I checked out the hose size and they are available from here cheaper than Dan, but sorry I can’t remember size, but easy for you to measure., or I can re measure later in week.
Post #528100 15th Sep 2019 4:22pm
Page 4 of 5 <12345>
