![]() | Home > Technical (L322) > Splutter, jerk, judder restricted performance mystery SOLVED |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Wow Nino thank you! Is there any photo you don’t have?
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
engine not running, when you give contact, car checks operacion of the turbo actuator. it goes up and down and makes klik / klak sound. when you learn the sound it can be heard from inside car every time you give contact. 2012 TDV8 Black Edition
Ok thank you - but what do you mean ‘contact’?
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
He means turn the key to the start position ie feed current to the starter. John
like when you checking oil level, Greg. press starter button without pressing the brake pedal. |
Thanks John & Nino for clarifying.
Also, another question for the team:
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
I think you have the original weaker ones Greg.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3860 ![]() ![]() ![]() |
Greg,
Close up picture of my replacement hose/s
Greg, if there are no cracks in the ruber, no need to change. I am at 230K km and hoses look good. and I like look of the originals better/more to it then just rubber hose/. 2012 TDV8 Black Edition
Thanks Mike & DrRob, super helpful!
I was replacing serpentine belt Greg, and it is much easier if you take valve out. i did check valve and it was ok. applied some white grees and reinstall. 2012 TDV8 Black Edition
Greg,
