Home > Maintenance & Mods (L322) > "Lumpy" brake disc face
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Just been checking rear discs on my 2004 L322 V8 petrol.
There is a little lip on edges, but when I run my finger across the face, you can feel ridges, not sharp, but highs and lows.
Is replacement needed? Could that be the cause a tiny vibration at speed?
Cheers
Post #528056 15th Sep 2019 11:40am
Like Saturn's rings ?
Sounds fairly normal to me (have had those on just about every brake disc, ever....) .
Post #528070 15th Sep 2019 12:58pm
rjff
^ +1 with Joe.
If you have a vibration, try checking the wheel hub areas/discs for an increased temperature on one or more after a run. If so you may have a sticky caliper causing a little binding which comes about when the car is driven for a distance. And use the back of your hand to check from the outer rim inwards!!
Quite a bit here about this if you search. Cheers
Richard
Gap IIDBT
Post #528101 15th Sep 2019 4:25pm
philip1972
Great, thanks both Thumbs Up
Post #528110 15th Sep 2019 6:08pm
rjff
Thumbs Up Cheers
Richard
Gap IIDBT
Post #528112 15th Sep 2019 6:13pm
