Home > Technical (L405) > stop start
Page 3 of 5 <12345>
Ukandrewf
there's a power outlet in this vent section also. does that whole section with the outlet come off easily? just a flat screw driver under trim? anything else you can advise. don't want to break anything #expensive
start/stop is winding me up --
On my third Full Fat RR
Post #528367 17th Sep 2019 7:11pm
look at the pic in my previous post..if yours is the same just take out that plug... ... - .- -.
Post #528369 17th Sep 2019 7:15pm
Ukandrewf
i only saw the one picture showing which wire to disconnect. is there another thread?
Post #528371 17th Sep 2019 7:30pm
thats the pic and thats the plug that is disconnected...
the panel that you take off is on the right as you stand looking into the boot ... - .- -.
Post #528372 17th Sep 2019 7:41pm
Ukandrewf
stan wrote:
off side rear cubby...grab hold of the vents and pull away.... Thumbs Up
i thought 'off side' was passenger side. (glad i didn't try pulling anything today) Very Happy --
Post #528373 17th Sep 2019 7:53pm
i figured you were thinking that when you mentioned the power socket Laughing ... - .- -.
Post #528374 17th Sep 2019 7:57pm
Ukandrewf
Can’t work out how it come off it it should come off and don’t want to break it. Seems to be a hand hold but assumed there would be a latch or something. --
Post #528493 18th Sep 2019 9:15pm
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
I shut mine off because 1.) irritating 2.) wear and tear on starter 3.) wear and tear on engine 4.) battery drain. Totally ridiculous thing and a way to tease up MPG for regulations IMO. Mine has a button. Our Mercedes has a button which you have to press every single time despite shutting it off in the menu, dealer shut that one off for us.
Post #528497 18th Sep 2019 10:02pm
Ukandrewf
totally agree brad. trying to run mine off.
stan any advice on how to open?
Andrew --
Post #528568 19th Sep 2019 9:49pm
the panel is fixed by 3 plastic thingys Andrew, grab hold of the 'vents' and pull...
Post #528569 19th Sep 2019 9:55pm
swissomatic
United States 2015 Range Rover 5.0 SC V8 Fuji White
For those of you in USA there appears to be a sensor which detects ethanol in the fuel and disconnects the stop start. Mechanic at dealer identified. Not sure it’s deliberate or accidental on part of LandRover as most FFs in US would be filled with up to 10% ethanol if you use the higher octanes. If you run a couple of tanks of non ethanol slightly lower octane the stop start feature returns. My understanding is that there are a number of inputs which cause stop start activation including ambient temp, HVAC status, engine fan operation etc.
interestingly I also have a Porsche Cayenne Hybrid S and have given up trying to figure when and how it uses stop start, battery, battery plus engine etc. when I asked the Porsche dealer he said don’t worry someone (German) much smarter than me has figured out the logic. Maybe same individual who figured out how to defeat the diesel emissions test. Probably out of work or in jail.
Post #528661 20th Sep 2019 9:53pm
brad s1
hey stan any recommendation on where to find a repair manual/what one to get? thanks.
Post #528734 21st Sep 2019 6:33pm
Ukandrewf
[quote="stan"]the panel is fixed by 3 plastic thingys Andrew, grab hold of the 'vents' and pull...
so we're pulling horizontally into the main load space area. (not down or on an angle) --
Post #528740 21st Sep 2019 8:49pm
thats right andrew Thumbs Up ... - .- -.
Post #528742 21st Sep 2019 9:09pm
Ukandrewf
Ok this confused me when I got cover off.
Found the large back battery I think but didn’t see what u reported.
duplicates which might give better image?
Post #528867 23rd Sep 2019 5:57pm
Page 3 of 5 <12345>
