![]() | Home > Technical (L405) > stop start |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
look at the pic in my previous post..if yours is the same just take out that plug... ... - .- -.
| Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 251
i only saw the one picture showing which wire to disconnect. is there another thread?
thats the pic and thats the plug that is disconnected...
i thought 'off side' was passenger side. (glad i didn't try pulling anything today) On my third Full Fat RR |
i figured you were thinking that when you mentioned the power socket |
| brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134
I shut mine off because 1.) irritating 2.) wear and tear on starter 3.) wear and tear on engine 4.) battery drain. Totally ridiculous thing and a way to tease up MPG for regulations IMO. Mine has a button. Our Mercedes has a button which you have to press every single time despite shutting it off in the menu, dealer shut that one off for us. |
totally agree brad. trying to run mine off.
the panel is fixed by 3 plastic thingys Andrew, grab hold of the 'vents' and pull...
| swissomatic Member Since: 16 Feb 2016 Location: Charleston SC Posts: 49
For those of you in USA there appears to be a sensor which detects ethanol in the fuel and disconnects the stop start. Mechanic at dealer identified. Not sure it’s deliberate or accidental on part of LandRover as most FFs in US would be filled with up to 10% ethanol if you use the higher octanes. If you run a couple of tanks of non ethanol slightly lower octane the stop start feature returns. My understanding is that there are a number of inputs which cause stop start activation including ambient temp, HVAC status, engine fan operation etc.
hey stan any recommendation on where to find a repair manual/what one to get? thanks. |
[quote="stan"]the panel is fixed by 3 plastic thingys Andrew, grab hold of the 'vents' and pull...
thats right andrew |
Ok this confused me when I got cover off.
| All times are GMT |
