Home > Technical (L322) > 4.4 TDV8 MAP sensor
Page 9 of 10 <12345678910>
nino_nino
I did with no ill efect. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #528525 19th Sep 2019 11:54am
GGDR
Just found this on another post:
Quote:
Called the Land Rover assist who arrange for the technician to meet me at my house about 2 hours later.
He opened the bonnet removed the engine cover and removed the MAP sensor. He said it was quite common. he showed me the sensor which had a thick layer of soot on it, about 3mm. He cleaned it with brake and clutch cleaner and replaced it, he put it on the computer and cleared the fault message and all good.
. Cheers, Greg
Post #528531 19th Sep 2019 2:12pm
Baltic Blue
I have cleaned my MAPF sensor several times with spray brake cleaner, seems to work well.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #528594 20th Sep 2019 8:22am
misfire84
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
During an idle moment I removed the MAP sensor from the inlet manifold and even though I thought the car was going well, The sensor in the manifold was a solid lump of carbon , lots of brake cleaner later and re installed it with aa smear of silicon grease on the o ring . then starting up what difference ! idle improved and it went much better or was it all in the mind ! .
what worries me is i dipped a screwdriver in the hole ( as you do !) and it came out with a big lump of oily stuff now i am working up courage to remove the inlet manifold and clean it out and replace the rubber hoses ( 4 off ) .
which type standard or go for silicon ( red ) ? 2012 Black 4.4 TDV8
1968 Mgb Gt
Post #641054 27th Aug 2022 11:19am
kevinp
My favourite picture of what I got out my plenum chamber.
I put red silicone hoses on mine.
Post #641055 27th Aug 2022 11:30am
Baltic Blue
We can’t really argue with Pete when he calls them dirty diesel devils Rolling with laughter
Post #641056 27th Aug 2022 11:37am
misfire84
That's what I am worrying about !! i feel a box of rubber gloves and a shed load of brake cleaner coming up 2012 Black 4.4 TDV8
1968 Mgb Gt
Post #641058 27th Aug 2022 12:21pm
garyRR
The hoses are 70mm internal diameter. Buy whichever you fancy - lengths are around £10-15. 2015 Range Rover Autobiography 4.4 SDV8
Post #641059 27th Aug 2022 12:41pm
kevinp
I'll be honest and if money was no object I'd just buy a new plenum chamber!!
Dirtiest job I've ever done. If you do do it get plenty of wire coat hangers, dish washing brushes, them long wire brushes, string to drag cloth through etc etc.
Post #641060 27th Aug 2022 12:42pm
DrRob
I'm tempted to go the new plenum route....are they expensive? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #641074 27th Aug 2022 3:32pm
JayGee
I bought a used one and cleaned it but it was a horrible job and wasn’t even that dirty. Still not got round to fitting it…… 2012 TDV8 Vogue (L322)
Post #641081 27th Aug 2022 4:08pm
Chrali
"I'm tempted to go the new plenum route....are they expensive?" They're about £500 quid for a genuine one. Luckily I didn't have to pay it. Encourage alternative fuels, use all the petrol!
2012 Range Rover Vogue 4.4 TDV8
2006 Mercedes GL420 CDI
2006 Porsche Cayenne Turbo S
2006 Jeep Commander 3.0 CDI with GDE HOT Tune
1997 Nissan Patrol 4.2 GRSE
1995 Vauxhall Monterey Diamond 3.2 v6
1994 Range Rover 4.2 LSE Beluga Black, Softdash, Brooklands Body Kit - Loved it!
1993 Range Rover 4.2 LSE ended up converted to 300tdi
Post #641262 28th Aug 2022 9:31pm
pcourtney
holy moly, does this ever get cleaned out by main dealers when doing a major service ??
what size is that tray, it looks like a lot of gunge there Sad
Post #643737 23rd Sep 2022 6:17pm
kevinp
It's a Chinese take away container. There was about half that much again. I was very concerned about the amount I got out but apparently it is quite 'normal' with EGR's and the like.
Post #643740 23rd Sep 2022 7:06pm
Mitch l_2000
Just wondering if anyone knows on the right hand map sensor (looking into the bonet) should that be pulling in air in as in live data it's reading 0 where as the left is giving a measurement that turbo was replaced about a year ago only noticed it as trying to clean egr as keeps going in to restricted power due to egr temp sensor 118k tdv8 4.4 westminister
Post #679360 3rd Dec 2023 7:37pm
