Home > Technical (L405) > Adding a new smart key?
andygts
Can the IIDTool add a new smart key and is there a way to tell if the KVM unit has had the LR update to make it a one time program unit?
I've just been into LR and tried my luck at ordering a new key and asked if they could check if the update was done. No luck though they just quoted for whole lot less fitting and programming. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #528541 19th Sep 2019 4:35pm
Send Pat @ GAP an email asking if they can help... Thumbs Up
Post #528574 19th Sep 2019 10:31pm
Not sure which software update you're referring to, but I had my software updated around 3 years ago, something to do with locks.
I bought a spare key from eBay & just handed over the 3 keys when they did the update - they needed all the keys - and it came back with all 3 working.
The only slight problem I have is that one of the keys can't be used manually as there is no matching cut piece, but I can live with that.
Post #528593 20th Sep 2019 8:14am
ask our site sponsor bushy,
https://www.fullfatrr.com/forum/lr-keys-vf...b849120c76 ... - .- -.
Post #528595 20th Sep 2019 9:11am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I spoke with GAP about this 6 months ago and it wasn't possible to add a key on an L405. Maybe thats changed by now ??? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #528602 20th Sep 2019 10:02am
Alistair, JLR updated the Key ECU locking it so a key could only be added with a code from factory! Yours may not of had that update? Mine had, my wife’s D4 had NOT! I could add a key to hers and not mine! Patrick sorted mine from memory? Hence my above post sir... Thumbs Up
Post #528604 20th Sep 2019 10:20am
Was that a recent change Craig ?
Mine had some lock software update but it was 3 years ago.....
Post #528656 20th Sep 2019 9:08pm
Im unsure Alistair... This all took place 18months ago or so, maybe when the car thefts were heavily publicised?
Post #528670 20th Sep 2019 11:35pm
Thanks - I've not had that one then.
Post #528681 21st Sep 2019 7:56am
Post #528692 21st Sep 2019 8:55am
andygts
Update
Messaged GAP and the reply was to just try coding a key to find out.
I had an idea of plugging in the IIDTool and checking if anything wanted an update, sure enough the KVM was on the list of updates, thought I was onto a winner.
I decided to use a local ish guy that I've used a few times over the years for new keys, I have a habit of buying cars with only 1 key Big Cry. Long story short, LR have had their grubby mits on the car and the KVM is locked.
Turns out if you know how then the KVM can be unlocked but it isn't a 2 minute job as the KVM has to be removed and surgery carried out on the bench, he's coming to me on saturday to hopefully delete the missing key and add another all for £250.
Bits from LR come in @ £450, key blade, smart key and KVM then labour ontop so probably £800. Current
Previous
Post #528960 24th Sep 2019 7:51pm
dolph34
Complete keys on the bay for less than 40 pounds , just ( !!!) Need coding. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #528961 24th Sep 2019 7:57pm
