![]() | Home > Technical (L322) > transmission transmission oil td6 complete |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 ![]() ![]() ![]() |
tools, many homemade
other vision in detail
I did not take pictures of the oil cup, and of the filter because those have already been seen |
Filling phase
other view of the filler cap
Now we proceed with the emptying of the converter and the cooling radiator.
Once the liquid has been drained, refit the upper tube as shown in the photo (with the new o-ring)
tighten the collar, with the lower tube disconnected, and insert a drain extension in it (white tube)
For this operation, you need to be in two, or put a longer drain pipe
leave the hose connected
Top up with about 3 liters and start the engine.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Thanks for the write-up and pictures. I am sure this will be of help to anyone doing a fluid change who wants to get the old oil out of the torque converter via the cooler lines. 2007 TDV8 VSE
