Home > Technical (L322) > Horn Fuse/Relay
Jim_m_kidd
2015 Range Rover Autobiography SDV8 Loire Blue
Horn Fuse/Relay
Hi,
Done quite a bit of searching here and on the internet generally but can't find anything definitive.
Trying to sort a problem with my horn not working at all and trying to find associated relay and fuse.
I think the relay is behind the fuses in the passenger glove box but not looked yet - the one I'm really struggling with is the Horn fuse...
Don't think it is in the glove box or rear compartment boxes - not listed in the owners handbook - I think that it is in the under bonnet fuse box but then I cannot find a description of which one it is.
There are several posts on her about similar, but I couldn't find one that gives anything definitive.
Any search wizards or fuse box experts that can give any guidance is much appreciated!
Jim
Post #529024 25th Sep 2019 10:33am
from memory i think its in the fuse box on the left hand side of the engine bay.
have you looked in the WM? ... - .- -.
Post #529027 25th Sep 2019 10:51am
Jim_m_kidd
Hi - yep can confirm its on the left of the engine. Opened it up and there are fuses in there. The workshop manual doesn't seem to get into fuses and relay level - the horn section describes how to get at the physical horns and change them out.
I did also find an electrical guide and also a section extracted from Topix on fuses but both these seem to be for ~04-06 models Sad
Cheers anyways!
Post #529061 25th Sep 2019 4:04pm
isnt there a diagram on the fuse box lid? ... - .- -.
Post #529063 25th Sep 2019 4:11pm
Jim_m_kidd
Hi - there is one in the main glovebox fuse box - but not in the one in the engine - in the handbook it says fuses under the hood not to be touched unless by technician! So they don't tell you.
None of the other fuse boxes would appear to contain one that is marked 'Horn' - maybe the horn is that dangerous!
Post #529065 25th Sep 2019 4:20pm
Brian Considine
You could always check the fuses with the ignition off.
Don't know if it is the same with RR's but on my last vehicle (VW Transporter T5) if you pulled ignition fed fuses with the ignition on you could get an airbag warning light on which would have to be reset via a diagnostics tool - maybe someone could advise me on this. 2003 Range Rover Vogue TD6
Post #529143 26th Sep 2019 11:27am
