Home > Technical (L322) > Selecting Access height
Clubman
Portugal 2011 Range Rover Vogue TDV8 Zambezi Silver
On the drivers door, above the window switches, there's a button that is suppose to lower the car to access height. but when I pressed it, with the car stopped, engine running , I didn't noticed it moving, but on the 4x4 info it showed that it was on low height. Is that difference that little, or does it move that slow that we don't notice it that much ? when I selected high suspension I did notice the car raising, and from outside we could clearly see that it was much higher .
going to pick up the car tomorrow, just wanted to be sure everything is in order before I pay the bill !
Post #529226 26th Sep 2019 10:41pm
It drops a couple of inches and movement is obvious when I park mine up with headlights on against a wall, but not that noticeable when just out in the open. What you can see is the lowering tell tale on the console flashing and then the access height light up once done. Obviously all movement stops if someone opens a door... Mike - MPx
Post #529228 26th Sep 2019 10:48pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Definitely should be a noticeable difference. If you're concerned, just take a tape measure and check the distance between the centre of a wheel and the bottom of the wheel arch? 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #529229 26th Sep 2019 10:49pm
Clubman
I think I will, I might just be me being paranoid, but is my hard earned €€€ on the line !
do we get any information on the main screen ?
Post #529234 26th Sep 2019 11:16pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
I used that for dogs last weekend but it sank much less then my previous FF 's.
May be calibration issue or new version is different. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #529259 27th Sep 2019 9:25am
dazza1983
You should feel it drop for sure.
Best way to test is get out the car press the button and close the door then watch to see if it drops. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #529531 29th Sep 2019 10:33pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
With the GAP tool you can change the heights.
Post #529538 30th Sep 2019 8:01am
