Home > Maintenance & Mods (L322) > Possible blown front air suspension air bag or is it!!
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys any help on this one much appreciated I was reversing onto my drive and lowered my air suspension and heard a bang and rush of air and the front end of the car will not raise the rear is fine it’s at normal ride height but the front end will not raise all I can hear is a rush of air from the front but nothing. I get no faults showing on my IID tool either is this likely to be a compressor fault or an individual air suspension fault air bag blown etc... Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #529308 27th Sep 2019 6:52pm
sounds like a bag has deflated... ... - .- -.
Post #529310 27th Sep 2019 6:56pm
jaysta10k
Hi guys update car has now gone down on all corners won’t raise any corners and the air compressor sounds like it’s struggling I’m getting message on dash saying car raising slowly but then get suspension fault not to go over 30 and orange light on height selection goes off.
Got this fault on IID tool
RLM-Suspension
C1130-7A (AF) Air spring air supply - Mechanical failure - fluid leak or seal failure
( on 27-09-2019 19:12:03 at 266002 km ) Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #529312 27th Sep 2019 7:23pm
jaysta10k
Is there anyway of raising the car back to normal ride height and taking out the fuse to disable the air compressor. It just seems bizzare that all corners are now down and none will raise. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #529313 27th Sep 2019 7:31pm
RRHSE06
United States
When my front airbags went out, the air compressor kept running until it overheated. You will receive a message on console 'unit needs to cool off, system down'. I don't think there is a way to raise the car to normal height with a leak in system. I took fuse 57 out to prevent the air compressor from running until I fixed my air springs.
Post #529640 1st Oct 2019 1:21am
GraemeS
Australia
Will your IIDtool raise the 3 good corners 1 at a time? It will for MY07-on models.
Post #529642 1st Oct 2019 3:31am
jaysta10k
It turned out to be a failed front driver side strut. I have noticed that the car seems to be sitting a bit higher now though at the front in normal ride height and a bit lower at back. Any ideas. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #530246 7th Oct 2019 1:44pm
