![]() | Home > Maintenance & Mods (L322) > Slight front end knock |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
I’ve just had my track rod ends done and encountered the exact same problem. The inners were so cheap it made sense to do the lot |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 ![]() ![]() ![]() |
I have got exactly the same problem with my track rod ends. You will probably find that the adjusters on the rear suspension are seized up too. |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Rear end is the next job unless my fitter says he's freed them and anti seized greased them |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
I just replaced the rears and they were solid did the fronts a few weeks ago due to wear inner and outer when I took the nearside inner out it was cross threaded - I have had the vehicle since 60k miles now on 185k so guess it came out the factory like that mmmm |
Well all good now new o/s lower arm full new inner/ outer track rod on both sides 4 wheel tracking done , FF feels kind of stable and positive on the road now all done and came in under £300 inc tracking |
