Home > Maintenance & Mods (L322) > Cornering lamps 2010 Vogue |
Hozza12163 Member Since: 10 Sep 2019 Location: Bedford Posts: 51 |
I don't seem to have any bulbs fitted for this but can I simply fit them and switch it on with the IID tool and it will work?
6th Oct 2019 12:49pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7640 |
You will need to buy 2 new headlights at least..... I don’t have them in mine either.
7th Oct 2019 10:21pm |
challenge accepted! Let's find a way to do this, I have a hammer and some glue, how hard can it be! FFRR
7th Oct 2019 10:36pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
I already said they are led if you have the Silver you have them if it’s black you don’t - here are mine
8th Oct 2019 4:08pm |
I have the same silver corner reflector but there aren't the little bulbs that I can see in yours, can I add them? FFRR
8th Oct 2019 7:18pm |
Oh really?
8th Oct 2019 10:56pm |
I'll pull the whole thing out at the weekend and have a proper look FFRR
8th Oct 2019 11:14pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Dan, 2009-2011 Grey lamps all have the reflector BUT, only lights equip with AFS have cornering light LED's fitted! Lesser models just have a hole where the LED's would have been... 2012 Gloss Black internals only had the reflectors fitted in AFS lamps... |
8th Oct 2019 11:27pm |
Pulling them out would mean the removal of the front bumper. Then even if you get the headlamps broken apart (they have different bonding glue to a 2007> lamp) the wiring and programming won't be in the headlamp/ECU... Not sure its achievable sir... |
8th Oct 2019 11:32pm |
TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198 |
Ok, I have not had my FFRR very long but it looked liked I might have an intermittent fault with the N/S headlight as it seemed to come on then off sometimes.
9th Oct 2019 10:19am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
Yup, they are a bit of a gimmick tbh |
9th Oct 2019 12:21pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34943 |
on my 2008 SC i took the bulbs out as it was disconcerting when you went round corners... ... - .- -.
9th Oct 2019 12:27pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1133 |
They are good for BMW drivers |
9th Oct 2019 4:22pm |
