Home > Maintenance & Mods (L322) > Cornering lamps 2010 Vogue
Hozza12163
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
I don't seem to have any bulbs fitted for this but can I simply fit them and switch it on with the IID tool and it will work?
I'm guessing it's triggered by the steering angle sensor?
if so, which bulbs do I stuff in?
I have the non-adaptive headlamps
Thanks in advance to anyone who knows and can "enlighten" me Rolling with laughter
 FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #530166 6th Oct 2019 12:49pm
Danwilderspin
There are no bulbs they have powerful leds in if you look from the ground up at them Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #530279 7th Oct 2019 9:22pm
mjdronfield
You will need to buy 2 new headlights at least..... I don’t have them in mine either.
https://www.fullfatrr.com/forum/topic35894...=cornering 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #530281 7th Oct 2019 10:21pm
Hozza12163
challenge accepted! Let's find a way to do this, I have a hammer and some glue, how hard can it be! FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #530282 7th Oct 2019 10:36pm
Danwilderspin
I already said they are led if you have the Silver you have them if it’s black you don’t - here are mine
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #530317 8th Oct 2019 4:08pm
Hozza12163
I have the same silver corner reflector but there aren't the little bulbs that I can see in yours, can I add them? FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #530329 8th Oct 2019 7:18pm
Danwilderspin
Oh really?
I have seen them with no silver as well so I assumed if you had silve you had bulbs - I think you’d need to get quite heavy handed with the light... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #530345 8th Oct 2019 10:56pm
Hozza12163
I'll pull the whole thing out at the weekend and have a proper look FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #530348 8th Oct 2019 11:14pm
Danwilderspin wrote:
Oh really?
Dan, 2009-2011 Grey lamps all have the reflector BUT, only lights equip with AFS have cornering light LED's fitted! Lesser models just have a hole where the LED's would have been...
2012 Gloss Black internals only had the reflectors fitted in AFS lamps...
Post #530350 8th Oct 2019 11:27pm
Pulling them out would mean the removal of the front bumper. Then even if you get the headlamps broken apart (they have different bonding glue to a 2007> lamp) the wiring and programming won't be in the headlamp/ECU...
Not sure its achievable sir... Neutral
Post #530351 8th Oct 2019 11:32pm
TJRL
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Ok, I have not had my FFRR very long but it looked liked I might have an intermittent fault with the N/S headlight as it seemed to come on then off sometimes.
After reading this thread and checking my vehicle what I thought was a headlight fault was in fact the cornering lamps working just as they should. Embarassed
I have to say, now that I know, they do not seem to add much vision in normal use. But I suppose they could be useful occasionally when in a tight spot or if you had the 360 camera set-up (I don't). IMHO, if you do not have them you are not missing much. 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
1960 Land Rover SII SWB SW
2020 BMW R1250 RT LE
2021 Triton ST-125 (Monkey Bike)
Post #530369 9th Oct 2019 10:19am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Yup, they are a bit of a gimmick tbh
Post #530384 9th Oct 2019 12:21pm
on my 2008 SC i took the bulbs out as it was disconcerting when you went round corners... ... - .- -.
Post #530385 9th Oct 2019 12:27pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
They are good for BMW drivers Rolling with laughter
Post #530409 9th Oct 2019 4:22pm
