Home > Maintenance & Mods (L322) > EGR: blanking or full remove? TD6
Walter Skinner
Bulgaria 2019 Range Rover Autobiography 2.0 PHEV Barolo Black
Decided to get rid of EGR since I doubt it works anyways.
There are two "kits" available for this purposes:
Simple installation: Ebay URL
Advanced, with hoses removal: Ebay URL
What is the practical difference except removing some additional weight? Which one is better?
Thanks!
Post #530328 8th Oct 2019 7:16pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I went for the easy option and just replaced the EGR, leaving the hoses and other gubbins.
It takes about 15 - 20 minutes. To be honest I have not noticed much of a difference but for the engine to now be breathing air rather than recirculated combustion gases it must be better for the car in the long run.
Jim
Post #530331 8th Oct 2019 7:29pm
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
I bought the fuller kit, but it was enough of a faff that I ended up just using enough bits to blank it, rather than doing the lot. Blanking was very quick, can't see the benefit of going all the way
Post #530333 8th Oct 2019 7:43pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
I purchased the kit and it didn't fit properly . In the end I just removed and plugged the vacuum pipe - job done.
Post #530356 9th Oct 2019 7:38am
MarshallW11
Canada 2003 Range Rover Vogue Td6 Giverny Green
If you do end up just doing the blank instead of the removal, make sure you verify that the bolts holding on the EGR cooler are secure.
I ended up doing the full removal because my EGR block off snapped due to vibrations coming from where it attached to the loose EGR cooler. I ended up removing the whole EGR and the EGR cooler system blankled to the exhaust. The car now heats up significantly quicker and doesn't have the running cold problem it did before.
Here's a link with some pictures of my problem in case you're curious:
https://www.fullfatrr.com/forum/topic51131.html
Post #530383 9th Oct 2019 12:07pm
