![]() | Home > Maintenance & Mods (L322) > EGR: blanking or full remove? TD6 |
Walter Skinner Member Since: 02 Oct 2019 Location: Varna Posts: 61 ![]() ![]() ![]() |
Decided to get rid of EGR since I doubt it works anyways.
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
I bought the fuller kit, but it was enough of a faff that I ended up just using enough bits to blank it, rather than doing the lot. Blanking was very quick, can't see the benefit of going all the way |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
I purchased the kit and it didn't fit properly . In the end I just removed and plugged the vacuum pipe - job done. |
MarshallW11 Member Since: 24 Jan 2019 Location: Ottawa Posts: 18 ![]() ![]() ![]() |
If you do end up just doing the blank instead of the removal, make sure you verify that the bolts holding on the EGR cooler are secure.
