Home > Maintenance & Mods (L322) > Vacuum brake bleeding |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3680 |
Nino is your man.
10th Oct 2019 11:16am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 696 |
Brilliant Mike
10th Oct 2019 11:44am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
here you go , cass,
10th Oct 2019 12:40pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
used an eezibleed many times and they work fine - when they work! typically, the seal at the top of the bottle starts to leak after you've used them a few times and brake fluid everywhere (buy a sheet of 3mm cork and produce new seals).
10th Oct 2019 2:15pm |
dexion7 an easy fix
10th Oct 2019 3:23pm |
I'm not sure that the corrosion on those nipples would have caused the problems that I experienced.
10th Oct 2019 3:30pm |
Thanks Nino, some great ideas there, I hadn't thought about changing the bleed nipples but it seems daft not to! |
10th Oct 2019 3:49pm |
actually, looking at that picture of the rusted nipple again, it does seem to be consistant with the symtoms that I experienced. the first coil of the thread (nearest the seat) is badly corroded and that coil would need to cut/grind its way through all the other threads in the body of the caliper in order to extract the nipple. since the original calipers are aluminium they would likely be scrap by then. |
10th Oct 2019 4:34pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
When you replace the bleed nipples and have tightened them and put the caps on, cover them with a liberal coating of grease.
10th Oct 2019 5:02pm |
