Home > Maintenance & Mods (L322) > Facelift Headlights
faz2kool
United Kingdom 2010 Range Rover Vogue 4.4 V8 Stornoway Grey
Facelift Headlights
Hi all
Need some help and advice. I purchased some genuine facelift headlights for my vehicle however after fitting them, i have an orange light on my dashboard with 2 arrows in each direction underneath. I've had this on the computer and it states the motor for each headlight is not working.
I was wondering if anyone has ever had this before and if there is away where I can switch off the adaptive headlights using the computer? Its possible that I have got the wrong headlights for the vehicle but ive been told these are the correct lights for this car.
Any help would be appreciated?
Faz
Post #530589 11th Oct 2019 2:32pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Cant remember but sure my old L322 that was 12 plate supercharged AB had directional headlights and hada symbol similar to that from memory?
Post #530618 11th Oct 2019 7:42pm
Brian Considine
Cant't help with the problem but I'd be interested in the drivers side headlamp if you still have the old ones. 2003 Range Rover Vogue TD6
Post #530627 11th Oct 2019 9:26pm
You need a diagnostics computer with the ability to turn on/off the Car Configuration File/s. Turn the headlamp file for the AFS system to Xenon/Non AFS and this will turn your orange lamp off sir Thumbs Up
An IID tool will do this Thumbs Up
Post #530629 11th Oct 2019 9:43pm
faz2kool
Thank You craig.
Just need to find someone who has this tool locally?
Faz
Post #530827 14th Oct 2019 12:15pm
faz2kool
Hi Craig
I tried the IID Pro tool today with LRKeys but this didnt work. Not sure why. Managed to get the Digital Display to show the mileage in numbers aswel as the Needle. However the Directional lamp in the bottom left corner and the fault for both headlamp motors is showing.
I'm guessin it could be a wiring fault. Will strip the front end off to get to the wires. ------------------------------------------------------
RR 4.4TDV8 2010
Mini JCW 2006
BMW 325i - 1992 (E30)
Post #537796 18th Dec 2019 4:52pm
Danwilderspin
The Po in my car (rightly or wrongly) took the fuse out and unsoldered the bulb... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #537843 18th Dec 2019 11:56pm
faz2kool
Its not the bulbs at fault. Its the Motors to make them adaptive. Apparantly the headlights I have bought do not have motors on them making them non adaptive when the car is trying to read for adaptive headlights.
When you switch the ignition on, the headlamp inside should move upwards, downwards etc to level themselves.
Mine dont do that. ------------------------------------------------------
RR 4.4TDV8 2010
Mini JCW 2006
Post #537880 19th Dec 2019 11:12am
Danwilderspin
sorry I meant the led / bulb in the cluster Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #537886 19th Dec 2019 11:41am
its me
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
So di I on a 2007 with a 2012 conversion. At the time the id tool couldn't do it, 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #537887 19th Dec 2019 11:44am
