![]() | Home > Maintenance & Mods (L322) > Facelift Headlights |
| DrF Member Since: 30 Jun 2014 Location: South East Posts: 1515
Cant remember but sure my old L322 that was 12 plate supercharged AB had directional headlights and hada symbol similar to that from memory? |
| Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428
Cant't help with the problem but I'd be interested in the drivers side headlamp if you still have the old ones. 2003 Range Rover Vogue TD6 |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
You need a diagnostics computer with the ability to turn on/off the Car Configuration File/s. Turn the headlamp file for the AFS system to Xenon/Non AFS and this will turn your orange lamp off sir |
| faz2kool Member Since: 11 Oct 2019 Location: Sheffield Posts: 42
Thank You craig.
Hi Craig
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2261
The Po in my car (rightly or wrongly) took the fuse out and unsoldered the bulb... Current stable:
Its not the bulbs at fault. Its the Motors to make them adaptive. Apparantly the headlights I have bought do not have motors on them making them non adaptive when the car is trying to read for adaptive headlights.
sorry I meant the led / bulb in the cluster Current stable:
| its me Member Since: 08 Mar 2013 Location: southampton Posts: 78
So di I on a 2007 with a 2012 conversion. At the time the id tool couldn't do it, 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
