![]() | Home > Technical (L405) > Jacking the L405 with side steps |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Your missing a trick sir... |
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 ![]() |
Thanks for the fast reply cam-tech-craig.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
you missed another trick, dont use the factory jack! get yourself a merc sprinter bottle jack..[other suitable bottle jacks can be used] ... - .- -.
Look in your owners manual and you will see the jacking point is exactly the same shape as the underside of the step hinge... That way you will know where to jack it sir... |
This im sure will help you sir...
Does this picture help?
Actually, I couldn't find it in the owners manual. |
I have a 2.5 ton trolley jack. But if I jack up using that, where will I place the jack stands then?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
It's the very lowest point that you jack from - dead easy with a trolley jack
There's a separate supplement for the deployable steps |
The lowest point is the one I marked in yellow. Is that it then? But that is plastic part of deployable side step..
Also, am I correct to say this is the point for jack stand or trolley jack as stated in the Workshop manual?
Yes the yellow part and NO its not plastic! Its metal... |
I'll see if a magnet sticks to it as when I touched it, knocked it, it didn't feel like metal.
[quote="Alistair"]It's the very lowest point that you jack from - dead easy with a trolley jack |
