Home > Technical (L322) > Coolant leak 4.4tdv8 |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2516 |
Oil cooler gaskets, at the back of the vee. |
13th Oct 2019 11:45pm |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
So does engine coolant go through the oil cooler then?
14th Oct 2019 7:25am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1459 |
It certainly does.
14th Oct 2019 7:57am |
Yeah, DrRob informed me about that mine looks to be ok. Regards
14th Oct 2019 8:18am |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 837 |
If it’s your oil cooler gasket you’ll see an oily film in the expansion tank - or worse obvious signs of oil floating on the surface if you remove the cap. |
14th Oct 2019 8:40am |
Didn’t notice any oil film when I topped it up yesterday. Regards
14th Oct 2019 8:44am |
SO No coolant leak found with a pressure test and no signs of a leak...
16th Oct 2019 4:20pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4231 |
You are losing oil and coolant. My money (£5 ) is on the oil cooler and it’s gaskets....
16th Oct 2019 5:50pm |
Well the dealer is stripping the car to get to the v to look at oile cooler and i think they said egr cooler also? Line was a really bad signal
18th Oct 2019 5:09pm |
Keep us posted
18th Oct 2019 5:34pm |
Grab a beer...
18th Oct 2019 5:42pm |
