Home > Technical (L322) > Coolant leak 4.4tdv8
dazza1983
Done a search but most coolant leaks referred to on here are for the 3.6.
Is there common areas for coolant leaks on the 4.4tdv8. Praying it’s not a head gasket.
Having a mare lately. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #530803 13th Oct 2019 10:18pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Oil cooler gaskets, at the back of the vee.
Post #530804 13th Oct 2019 11:45pm
dazza1983
So does engine coolant go through the oil cooler then?
Cheers Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #530809 14th Oct 2019 7:25am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
It certainly does.
Mine had a leak on the stupid designed plastic fitting in the top hose that goes to the expansion tank, a known weekpoint.
AJG BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #530811 14th Oct 2019 7:57am
dazza1983
Yeah, DrRob informed me about that mine looks to be ok. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #530813 14th Oct 2019 8:18am
JCW
If it’s your oil cooler gasket you’ll see an oily film in the expansion tank - or worse obvious signs of oil floating on the surface if you remove the cap.
Post #530814 14th Oct 2019 8:40am
dazza1983
Didn’t notice any oil film when I topped it up yesterday. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #530816 14th Oct 2019 8:44am
dazza1983
SO No coolant leak found with a pressure test and no signs of a leak...
So internal leak possibly???
Common internal coolant leaks?
I think the stealer is going to check the oil cooler... Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531126 16th Oct 2019 4:20pm
DrRob
You are losing oil and coolant. My money (£5 Whistle ) is on the oil cooler and it’s gaskets.... Whistle
Keep us posted on main stealer diagnosis Thumbs Up
Back of my cooler before fixing:
 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #531145 16th Oct 2019 5:50pm
dazza1983
Well the dealer is stripping the car to get to the v to look at oile cooler and i think they said egr cooler also? Line was a really bad signal
Its sounding expensive lol Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531338 18th Oct 2019 5:09pm
DrRob
Keep us posted Thumbs Up
I did offer to look at it for you. Would have cost you one whole pint of ale Rolling with laughter Whistle
If it is the oil cooler then hopefully will cure the oil and coolant issue Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #531341 18th Oct 2019 5:34pm
DrRob
Grab a beer... Thumbs Up
https://www.fullfatrr.com/forum/topic35977...oil+cooler
https://www.fullfatrr.com/forum/topic45147...oil+cooler
Post #531342 18th Oct 2019 5:42pm
