![]() | Home > Maintenance & Mods (L322) > wheel arch rubber seal |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Thanks |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3985 ![]() ![]() ![]() |
Which picture? |
Top one. I assume with door shut the 2 seals join nicely up against each other?
Top man 👍 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
LR strips cover all the lip....
Sorry I just can't get a picture that clearly shows contrast between the outer door seal and the cover strip applied to the wheel arch return. Suffice to say the outer door seal does indeed overlap the cover strip and effectively fully protects the rear arch return. Without the cover strip or the LR genuine part the rear arch is definitely susceptible to impact and potential corrosion. Applying either strip over a liberal coating of grease and cleaning yearly should stop the corrosion. |
Cheers for all the help |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
Good time of year to grease it up.
No the trim doesn't go round the kink.
Thanks!
Order placed for 2 of nicedayforits recommended rubber strips from eBay to replace the existing LR strips in arch and add to front of each arch |
All done today |
