Home > Maintenance & Mods (L322) > wheel arch rubber seal
Page 3 of 3 <123
DrRob
Thanks Bow down Thumbs Up
It looks like there is still some of the metal exposed with door open?
I guess with the door shut the door rubber seal butts up to the plastic strip nice and close?
Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530884 14th Oct 2019 8:33pm
Which picture?
Post #530887 14th Oct 2019 8:49pm
DrRob
Top one. I assume with door shut the 2 seals join nicely up against each other?
Same top picture with door shut would be great Bow down Thumbs Up Whistle Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530888 14th Oct 2019 8:52pm
I now see what you mean.
The original LR cover strips covered about the same amount of the metalwork if not slightly less.
The door seals overlap as far as I am aware but will have to look in daylight.
Post #530891 14th Oct 2019 8:58pm
DrRob
Top man 👍 Bow down
I assume you used the same rubber seal to do the entire wheel arch and not just the leading edge where door shuts? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530892 14th Oct 2019 9:02pm
mjdronfield
LR strips cover all the lip....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #530902 14th Oct 2019 10:56pm
Sorry I just can't get a picture that clearly shows contrast between the outer door seal and the cover strip applied to the wheel arch return. Suffice to say the outer door seal does indeed overlap the cover strip and effectively fully protects the rear arch return. Without the cover strip or the LR genuine part the rear arch is definitely susceptible to impact and potential corrosion. Applying either strip over a liberal coating of grease and cleaning yearly should stop the corrosion. Thumbs Up
Post #531114 16th Oct 2019 3:04pm
DrRob
Cheers for all the help Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #531123 16th Oct 2019 4:10pm
GGDR
Good time of year to grease it up.
Nicedayforit does your rubber run front right through to the rear?
If so how do you deal with the kink at around 12o'clock position?
. Cheers, Greg
Post #531152 16th Oct 2019 7:06pm
No the trim doesn't go round the kink.
I have two pieces fitted to each side split at the 12 o'clock position. They are fitted as close to the kink as I can get.
I rely on a coating of grease to cover the kink, seems to work, after 15 years still no corrosion to the rear arches.
Post #531157 16th Oct 2019 8:00pm
GGDR
Thanks!
Well done keeping the rot at bay!
Thumbs Up Cheers, Greg
Post #531158 16th Oct 2019 8:03pm
DrRob
Order placed for 2 of nicedayforits recommended rubber strips from eBay to replace the existing LR strips in arch and add to front of each arch Thumbs Up
Got a nice pot of bearing grease already Thumbs Up
Post #531159 16th Oct 2019 8:16pm
DrRob
All done today Thumbs Up
Removed old strips and cleaned out the crap from behind and left overnight to dry.
Lots of grease applied and new LR strips (LR001623) cut to size and fitted nicely to the trailing edges. 1 for each side cut to fit. £19 for both from Duckworths.
Also fitted the eBay sourced plastic trims to the leading edge of the lip where none existed before
Thanks for all the tips Thumbs Up Bow down
Looks factory fresh Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #536103 1st Dec 2019 8:34pm
Page 3 of 3 <123
