![]() | Home > Maintenance & Mods (L322) > TD6 - any way to test servotronic valve |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35809 ![]() ![]() |
you could disconnect it and see if that makes any difference.. ... - .- -.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Thanks Stan
many years since i did mine but from memory its behind the wheel arch plastic on the off side front.. ... - .- -.
Cheers Stan, will wait for the downpour to ease and climb under there this weekend with a bit of luck |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 712 ![]() ![]() ![]() |
Follow the track rod end inboard & you'll see it in front & above the driveshaft (you'll need the wheel off)
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Have you checked the uj's on the steering?
