![]() | Home > Maintenance & Mods (L322) > Should viscous fan come on full power when started? |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 566 ![]() ![]() ![]() |
I've noticed this on mine recently & I'm thinking that it may be due to the drop in temperature, where it's taking a little longer to reach the desired system sensing, If you get my drift. |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2236 ![]() ![]() ![]() |
I’m guessing you have the jag engined 4.4? If so likely we have the same thing. Did it do it last winter though? Current stable:
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
I was under the impression that a viscous coupling on a fan engages when cold and gradually disengages as it reaches it's operating temperature.
Your're right 4.4 AJ engine. Difficult to remember, but not had any cooling issues.
Found this on Rave.
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
My TD6 (2003 L322 Vogue) seems to do the same occasionally - will have to make a mental note of ambient temperatures in future. 2003 Range Rover Vogue TD6 |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2280 ![]() ![]() ![]() |
From memory the viscous fan if it has locked up ie engine was hot when you switch off it stays like that and doesn't reset until you restart - I may not be exactly correct but it is along those lines so I was told |
Thanks sandy - so does yours sometimes do the roar when it starts as you have the same as me for 60 seconds or so?
Yes not every time but most and I changed the fan as well as all pulleys alternator zircon compressor water pump etc when it was 10 yrs old did it before and still does it |
Thanks - do you get the buzzing sound in the video? Current stable:
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
There is no buzzing from mine (changed for a new one about a year ago).
Great stuff thanks Stu
Correct no buzz. The problem may be the pump is trying to pump air - it's pretty easy to check, just pull the top hose off, if coolant comes out all good, otherwise you'll need to prime it and then bleed it (see the WSM - ignition switch to II and then the bleed screw on the expansion tank).
