Home > Maintenance & Mods (L322) > Should viscous fan come on full power when started? |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
I've noticed this on mine recently & I'm thinking that it may be due to the drop in temperature, where it's taking a little longer to reach the desired system sensing, If you get my drift. |
20th Oct 2019 3:26pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
I’m guessing you have the jag engined 4.4? If so likely we have the same thing. Did it do it last winter though? Current stable:
20th Oct 2019 3:47pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 897 |
I was under the impression that a viscous coupling on a fan engages when cold and gradually disengages as it reaches it's operating temperature.
20th Oct 2019 4:14pm |
20th Oct 2019 4:15pm |
Your're right 4.4 AJ engine. Difficult to remember, but not had any cooling issues.
20th Oct 2019 4:49pm |
Found this on Rave.
20th Oct 2019 5:01pm |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
My TD6 (2003 L322 Vogue) seems to do the same occasionally - will have to make a mental note of ambient temperatures in future. 2003 Range Rover Vogue TD6 |
20th Oct 2019 5:24pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2224 |
From memory the viscous fan if it has locked up ie engine was hot when you switch off it stays like that and doesn't reset until you restart - I may not be exactly correct but it is along those lines so I was told |
20th Oct 2019 10:16pm |
Thanks sandy - so does yours sometimes do the roar when it starts as you have the same as me for 60 seconds or so?
20th Oct 2019 10:39pm |
Yes not every time but most and I changed the fan as well as all pulleys alternator zircon compressor water pump etc when it was 10 yrs old did it before and still does it |
21st Oct 2019 4:16am |
Thanks - do you get the buzzing sound in the video? Current stable:
21st Oct 2019 9:42am |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
There is no buzzing from mine (changed for a new one about a year ago).
21st Oct 2019 5:57pm |
Great stuff thanks Stu
21st Oct 2019 6:05pm |
Correct no buzz. The problem may be the pump is trying to pump air - it's pretty easy to check, just pull the top hose off, if coolant comes out all good, otherwise you'll need to prime it and then bleed it (see the WSM - ignition switch to II and then the bleed screw on the expansion tank).
22nd Oct 2019 5:39pm |
