![]() | Home > Maintenance & Mods (L322) > Should the auxiliary coolant pump buzz? |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2263 ![]() ![]() ![]() |
Current stable:
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 ![]() ![]() ![]() |
from what i have read here (on the 4.2 at least) this is normal when the ignition is on.
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
I’ve never heard mine make a noise like that |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1406 ![]() ![]() |
Bearings gone in the pump imo
well - I have recently (last week) had it log converted now its running okish and yes I have been randomly getting that - I thought it was related to the log conversion and am due to takeout back they told me the fuel pressure may not be quite right and can cause it. there was water in the top hose when I took it off and can hear it pumping when I bled the system after a thermostat change... Current stable:
https://rover.ebay.com/rover/0/0/0?mpre=ht...1082319764
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
I got mine from Amazon: https://www.amazon.co.uk/gp/product/B00BHKX9PA |
Oh yes same price may get that now swap out over the weekend...
Your call |
Yea I have brown pin one red pin two checked that already but all good I think Current stable:
Got new pump today but the wm say this about the bleeding
start filling the system as normal through the expansion tank, this will help alot.
What an absolute a hole - thought I’d do this after work tonight but the bolt was seized in took me ages to loosen it from the clamp and took over an hour to move the hose clips with pliers and swan neck as the sheath in the angled pipe kept getting caught. Ended up using grease but the bit still won’t move so looks like a weekend job to finish. Current stable:
Yep, can be a bit fiddly - I assume you took the headlight out to get at it? |
