Home > Maintenance & Mods (L322) > Should the auxiliary coolant pump buzz?
Danwilderspin
Had the key in the ignition (not started) and noticed when I was under the bonnet a buzz from the aux coolant pump - can someone tell me if this is normal ? I only ask because I have been having cooking system issues this week? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531536 20th Oct 2019 2:02pm
Danwilderspin
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531561 20th Oct 2019 7:00pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
from what i have read here (on the 4.2 at least) this is normal when the ignition is on.
the only thing that might be wrong is if its wired backwards...
i would check mine and tell you but its currently in the boot along with the rest of the engine awaiting parts arrival
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #531914 23rd Oct 2019 1:35pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
I’ve never heard mine make a noise like that Confused 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #531945 23rd Oct 2019 11:24pm
dingg1
Bearings gone in the pump imo
Have you been getting restricted performance when booting it over 70 or 80mph?
That would confirm diagnosis
Post #531956 24th Oct 2019 8:52am
Danwilderspin
well - I have recently (last week) had it log converted now its running okish and yes I have been randomly getting that - I thought it was related to the log conversion and am due to takeout back they told me the fuel pressure may not be quite right and can cause it. there was water in the top hose when I took it off and can hear it pumping when I bled the system after a thermostat change... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531989 24th Oct 2019 2:48pm
Danwilderspin
https://rover.ebay.com/rover/0/0/0?mpre=ht...1082319764
Seems a good deal don’t buy bits of the bay much but seems good Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #532039 24th Oct 2019 10:13pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I got mine from Amazon: https://www.amazon.co.uk/gp/product/B00BHKX9PA
Post #532040 24th Oct 2019 10:20pm
Danwilderspin
Oh yes same price may get that now swap out over the weekend...
If I as a braver man I’d get this and save a nifty
https://rover.ebay.com/rover/0/0/0?mpre=ht...2285950668 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #532043 24th Oct 2019 11:03pm
stu1
Your call Smile
Be sure to check the wiring to make sure it isn't wired backwards (putting LTB00041 into Google will quickly provide a PDF)
Post #532044 24th Oct 2019 11:14pm
Danwilderspin
Yea I have brown pin one red pin two checked that already but all good I think Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #532051 25th Oct 2019 7:33am
Danwilderspin
Got new pump today but the wm say this about the bleeding
NOTE: With the ignition key turned to position II the charge air coolant pump will run, to aid coolant bleed. Make sure the charge air coolant pump is primed prior to running the pump.
How the hell do you prime the pump? No Info in wm or is it just squeezing the hoses to the pump by hand? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #532356 27th Oct 2019 10:33pm
MattHughes86
start filling the system as normal through the expansion tank, this will help alot.
bot also above the pump by the top of the radiator there is a bleed screw for that system also, the other way is to fill into the supply pipe manually.
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #532409 28th Oct 2019 11:02am
Danwilderspin
What an absolute a hole - thought I’d do this after work tonight but the bolt was seized in took me ages to loosen it from the clamp and took over an hour to move the hose clips with pliers and swan neck as the sheath in the angled pipe kept getting caught. Ended up using grease but the bit still won’t move so looks like a weekend job to finish. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #532514 28th Oct 2019 10:53pm
stu1
Yep, can be a bit fiddly - I assume you took the headlight out to get at it?
Post #532565 29th Oct 2019 6:15pm
