Home > Technical (L322) > porous block. Coolant leak. As much help as possible please.
Page 1 of 4 1234>
dazza1983
cars been in land rover stealer for a week trying to diagnose a coolant leak, they are saying that its now a possible porous block?
Anyone heard of this? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #531622 21st Oct 2019 12:07pm
Fox889
A porous block on a 4.4tdv8 this new Shocked
Holy moly, I hope not! 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #531626 21st Oct 2019 12:32pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Only on 4.6 P38’s Shocked
Never heard of it on any other Range Rovers since...... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #531631 21st Oct 2019 1:01pm
cass
What have they found that makes them think it’s a porous block?
Not that I’m suspicious of anything a main dealer tells me but that sounds like the sort of guess they might make because they can’t find a leak?
Post #531633 21st Oct 2019 1:05pm
dazza1983
EMAIL I Received from them:
Good morning Darren,
I have spoken to Matt the Tech on your coolant leak. Its not great news I’m afraid. We have removed the intake pipe work and most of the items in the V.
There aren’t any signs of external coolant leak in the V from the oil cooler, we have removed the EGR Cooler to test and inspect, this is fine, no leaks or coolant staining.
We have removed the intake pipes to check for signs of coolant, (which could suggest a head gasket failure) but all are dry, with no staining or crystals.
The next step ref a LTB, is to re build the engine to a point we can road test the vehicle to get it hot, then drain the engine oil and re-fit the sump bung and leave the vehicle overnight, to see if any coolant passes into the sump.
We have seen this before, which strongly indicates a porous block.
At this point though I will need to ask for some diag time from you, we have spent about 3.5 hours on it FOC so far. To continue if you wish we need another 2 hours @ £100 per hour, (discounted).
Let me know your thoughts
Regards Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531634 21st Oct 2019 1:07pm
dazza1983
ive asked them to drop the oil now ans see if there is any seperation.. Ive put 1.5 litres of coolant in so should see something if thats where its going. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531638 21st Oct 2019 1:29pm
cass
Looks like l’m wrong - sounds like they are having a proper look but a porous block is still something that I thought had gone away decades ago
Post #531640 21st Oct 2019 1:41pm
Fox889
+1 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #531656 21st Oct 2019 3:10pm
I would get a second opinion. Thumbs Up
Post #531665 21st Oct 2019 3:45pm
dazza1983
I thought about that.. the trouble is bills strat getting huge Sad Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531669 21st Oct 2019 3:58pm
Fox889
I don't think you've got much choice chap.
They've gone this far, for a few hundred more you should get a definitive answer hopefully.
Be very interested to see what happens next. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #531673 21st Oct 2019 4:13pm
dazza1983
the question i have is:
what do i do if they say no collant leaking into sump? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531674 21st Oct 2019 4:15pm
Can they not pressure test the coolant system instead of just looking for signs of a leak.
Post #531675 21st Oct 2019 4:17pm
dazza1983
Apparently they have done that. it held pressure for 45mins Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531678 21st Oct 2019 4:21pm
dazza1983
oil has been dropped and no coolant is visable no seperation etc.. sump drain bung has been re installed and will be left overnight and cracked open again tommorow to see if any coolant comes out the sump..
Not sure where to go if it comes back all clear.
Possible airlock that cleared and the level dropped?
I was wondering about fuel burning heater or anything similar? Also CamTechCraig mentioned something about pipes for the rear heating.. ive asked the dealer about that also. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531683 21st Oct 2019 4:43pm
Page 1 of 4 1234>
