![]() | Home > In Car Electronics (L322) > Code abs module, Td6 2002. |
| Loyola1988 Member Since: 04 Mar 2019 Location: PARIS Posts: 8
thanx i'll try this week end |
No luck for me it still won't work maybe the argument is bad mine is a 03 V8 any body can give me the rgiht argument with tool32? |
| tveitan Member Since: 10 Dec 2016 Location: Norway Posts: 47
That's too bad. You're the second one who hasn't had any luck trying this. The argument is from, and used on a Td6. Tried it with two separate modules and it works fine. 2002 Range Rover Td6 |
Hello how did you pick up the argument? |
| Trombots Member Since: 24 Jun 2020 Location: Anglesey Posts: 1
Worked fine on my 2004 TD6 too! A real lifesaver, (well saved a few quid anyway!). Many thanks. I would really like to know if there is a reference guide somewhere for DSC_L30.prg. Must be able to do lots of other funky stuff with it. Cheers, Ed |
Hi. I found it when reading the config file from another RR Td6 2002 Range Rover Td6 |
Good to hear! I would like to know that as well |
