![]() | Home > Technical (L322) > oh poo! restricted performance tdv8 4.4 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Check the 4 donut hoses on intake. Have they been upgraded to the revised spec ones?
cozzy Member Since: 15 Jan 2019 Location: Norfolk Posts: 76 ![]() ![]() ![]() |
Pound to a penny its the doughnuts / intake hoses (x4) as above Said . I have a spare set if you need them !! |
Andy2986 Member Since: 26 May 2019 Location: Suffolk Posts: 117 ![]() ![]() ![]() |
hi Guys,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3554 ![]() ![]() ![]() |
Soot = you've almost definitely got a split then.
Good stuff ( i guess !!)
https://www.fullfatrr.com/forum/topic52120...p;start=15
Thanks guys, I had just found the piece on removing the plenum. |
Just thought I would post an update.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
If you’ve just gone straight to red warning, it may mean your car is not regenning automatically. Get your oil/fuel mix level checked as well as dpf soot levels. I had the same fault/situation and found my fuel in oil mix Level was 12 (7 is the warn level). I had oil and filter changed and then service reset on menu. This resets the oil fuel reading to zero. I went for a regen run yesterday and it worked within 4 miles if setting off.
Latest update and its not a good one |
I've not read about splits in manifolds for a while.
Hi Greg,
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3850 ![]() ![]() ![]() |
I only remember 2 splits in the actual manifold when I compiled my 4.4 tdV8 Fault Log thread, but quite a few more where the plenum section split, usually along the seam.
So.....
