![]() | Home > Technical (L322) > Is the rear spoiler adjustable at all? |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
There is probably a little bit of side to side/back and forth adjustment once you loosen the bolts. You will probably break some of the clips when removing the inner tailgate trim though... .
| gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163
Yes. There's quite a bit of movement in it. Takes a bit of trial and error to get the alignment correct. |
| dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529
Ah that’s good to know. Thanks guys.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
I did mine recently when I installed a new high level brake light |
Can you confirm there is adjustment left right forward and back mate? Regards
| chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 766
I’m no expert, but you don’t need to remove the plastic trim to adjust the spoiler Joe? 2014 vogue se |
ill hold fire then untill confirmed.. Regards
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2721
Yup, no need to remove plastic inner, bolt access easy enough with a socket |
Care to share the knowledge buddy?
| Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193
Open upper tailgate fully. Look between upper window trim and body. You will see 3 galvanised head hex bolt heads, one in centre, one each side. Loosen them them to adjust spoiler until washer on each is loose. Close tailgate and grasp rear edge of spoiler to move in or out. For side to side you may need to combine with in and out to work it across. If you take out one of the bolts you can see the relative size of adjustment hole and threaded hole which will give you an idea how much you can move it in any direction. When you are done open the tailgate and tighten the bolts. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
Thanks for this.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
You would only need to access the inner trim if you were removing the spoiler as the reverse camera and 3rd brake light wiring plugs are inside the inner cover...
In my experience only either to maintain/repair the rear wash/wipe motor and pipes, or to deal with aspects of the wiring if you need to replace the reversing camera with an aftermarket one.
