Home > Technical (L322) > Is the rear spoiler adjustable at all? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
There is probably a little bit of side to side/back and forth adjustment once you loosen the bolts. You will probably break some of the clips when removing the inner tailgate trim though... .
27th Oct 2019 4:29pm |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
Yes. There's quite a bit of movement in it. Takes a bit of trial and error to get the alignment correct. |
27th Oct 2019 5:47pm |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
Ah that’s good to know. Thanks guys.
27th Oct 2019 6:39pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4245 |
I did mine recently when I installed a new high level brake light Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
27th Oct 2019 7:06pm |
Can you confirm there is adjustment left right forward and back mate? Regards
27th Oct 2019 7:15pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 702 |
I’m no expert, but you don’t need to remove the plastic trim to adjust the spoiler Joe? 2014 vogue se |
27th Oct 2019 9:29pm |
ill hold fire then untill confirmed.. Regards
27th Oct 2019 9:58pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
Yup, no need to remove plastic inner, bolt access easy enough with a socket |
27th Oct 2019 10:20pm |
Care to share the knowledge buddy?
27th Oct 2019 10:27pm |
Nick591 Member Since: 04 May 2017 Location: Charfield Posts: 193 |
Open upper tailgate fully. Look between upper window trim and body. You will see 3 galvanised head hex bolt heads, one in centre, one each side. Loosen them them to adjust spoiler until washer on each is loose. Close tailgate and grasp rear edge of spoiler to move in or out. For side to side you may need to combine with in and out to work it across. If you take out one of the bolts you can see the relative size of adjustment hole and threaded hole which will give you an idea how much you can move it in any direction. When you are done open the tailgate and tighten the bolts. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
27th Oct 2019 10:42pm |
Thanks for this.
27th Oct 2019 11:07pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
You would only need to access the inner trim if you were removing the spoiler as the reverse camera and 3rd brake light wiring plugs are inside the inner cover...
27th Oct 2019 11:33pm |
In my experience only either to maintain/repair the rear wash/wipe motor and pipes, or to deal with aspects of the wiring if you need to replace the reversing camera with an aftermarket one.
