Home > Technical (L405) > 6 pot callipers |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2152 |
They’re on the SDV8. |
30th Oct 2019 10:45pm |
Felstmiester Member Since: 06 Apr 2019 Location: Hertfordshire Posts: 262 |
All of the sdv8 L405’s ? |
30th Oct 2019 10:56pm |
I can’t speak for anything prior to MY17, but certainly from then onwards |
31st Oct 2019 4:08am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1692 |
All 6 pots from L320/L322/L405/L494 are all interchangeable |
31st Oct 2019 6:23am |
The earlier model brembo’s was different though wasn’t they? If they’re not I’m gutted because I done the conversion on our disco to brembo but didn’t swap it back when I sold it because I thought they was smaller than the ones they put on the L405. |
31st Oct 2019 8:39am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
All JLR Brembo 6 pot callipers are the same LH & RH fitment... The earlier 4 pot callipers will NOT fit on a newer (2009>) models...
31st Oct 2019 12:06pm |
No offence to anyone but I knew you was the man to answer this question. In a way I’ve had a result then as I’ve found a breaker that has a sdv8 |
31st Oct 2019 12:46pm |
jz Member Since: 31 Mar 2016 Location: London Posts: 55 |
Seeing Mickley's comment so just to confirm, are all 6pots 100% inter-changeable across L322s, L320s, L405s
4th Nov 2019 11:12am |
Ahem... |
4th Nov 2019 7:50pm |
And the 6 pots just bolt on to the existing hubs of a D3 do they Mickey??? |
4th Nov 2019 9:53pm |
Same brakes as the early L320's |
5th Nov 2019 9:31am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2309 |
My brother's MY08 3.6 TDV8 RRS has 4-pot Brembos not 6. |
5th Nov 2019 10:19am |
So... 4 pot not 6! |
5th Nov 2019 11:07am |
Gents, sorry but just to be clear - as selling my 2010 L320 which has 6 pots, are they a straight fit for my 2011 L322 SC as would mind swapping them over as they're better condition but dont want to waste my time local mechanic if not? |
5th Nov 2019 11:27am |
