![]() | Home > Technical (L405) > 6 pot callipers |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
They’re on the SDV8. |
Felstmiester Member Since: 06 Apr 2019 Location: Hertfordshire Posts: 262 ![]() ![]() ![]() |
All of the sdv8 L405’s ? |
I can’t speak for anything prior to MY17, but certainly from then onwards |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1861 ![]() ![]() |
All 6 pots from L320/L322/L405/L494 are all interchangeable |
The earlier model brembo’s was different though wasn’t they? If they’re not I’m gutted because I done the conversion on our disco to brembo but didn’t swap it back when I sold it because I thought they was smaller than the ones they put on the L405. |
All JLR Brembo 6 pot callipers are the same LH & RH fitment... The earlier 4 pot callipers will NOT fit on a newer (2009>) models...
No offence to anyone but I knew you was the man to answer this question. In a way I’ve had a result then as I’ve found a breaker that has a sdv8 |
jz Member Since: 31 Mar 2016 Location: London Posts: 55 ![]() ![]() |
Seeing Mickley's comment so just to confirm, are all 6pots 100% inter-changeable across L322s, L320s, L405s
Ahem... ![]() ![]() ![]() |
And the 6 pots just bolt on to the existing hubs of a D3 do they Mickey??? |
Same brakes as the early L320's |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
My brother's MY08 3.6 TDV8 RRS has 4-pot Brembos not 6. |
So... 4 pot not 6! |
Gents, sorry but just to be clear - as selling my 2010 L320 which has 6 pots, are they a straight fit for my 2011 L322 SC as would mind swapping them over as they're better condition but dont want to waste my time local mechanic if not? |
