![]() | Home > Maintenance & Mods (L322) > Activating service intervals? |
| S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170
No way to make the car tell me when it wants to be serviced? 2007 L322 3.6 TDV8 Stornoway |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
not sure this is possible..any thing via the search function? ... - .- -.
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
Same problem on our 2006 TDV8.
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888
Try a reset by using the service/ test menu... instrument pack... service interval reset ?.
| nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 252
My 07my tells me when it needs a service, so must be possible Remember:- amateurs built the ark
I think my 2011 does, but I always reset it before it is due after doing a DIY service early.
| Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417
My 2012 does. I don't think it counted down though just popped up with 'Service Required' or similar. It hadn't been reset by the garage who did the full service (read oil change) when I bought it.
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277
AFAIK you can reset the service interval and when the service is due it pops up on the instrument panel but you can't access the information re time to run to next service.
I think you are both right..
| V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424
From 2005 you'll need something like AutoLogic to re-set the service due time. Not sure what year that stopped being relevant. Mine is a 2006 MY and cannot be re-set via secret menu's or similar.
You can also do it with the Gap iiD for the 2006 on. John
Attemptet an interval reset with the IID tool yesterday but just got "procedure failed" or similar. I'll try to do a print-screen when possible. 2007 L322 3.6 TDV8 Stornoway |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Did you have engine running? It has to be engine off but ignition on |
| All times are GMT |
