![]() | Home > Maintenance & Mods (L322) > Brake hose recall and turbo oil drain modification |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Turbo drain is very hard to tell unless on a ramp with under trays off.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3851 ![]() ![]() ![]() |
Two separate questions that needs 2 answers.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Brake recall should be able to be checked via the same GOV.UK website where you can check the MOT history of the car. Worth checking both |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
+1 on the brake hose recall about dealer or .gov website.
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
If a LR dealer put a 2011/12 cars VIN into his system would it show if the mod has been done?
Only if it was done at a MD.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1417 ![]() ![]() ![]() |
My recollection of the brake recall work is that it was recorded in the service book, where there was a separate section for recalls. As there was no charge for the work there was no invoice.
