Home > General > L322 specs
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
gonna_go_double_r wrote:
emailed (x2)
Thank you
Seems I may have the only Westminster with lots of added Spec!
Post #523378 31st Jul 2019 12:24am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Quote:
It's EPIC Roy
Fair enough! Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #523384 31st Jul 2019 7:18am
Rob99
The spec for each model varies for MY10 MY11 and MY12
Westminster replaced Vogue and Vogue SE for 12
PM me your email and I can send you a spec sheet and brochure.
Hi Greg
Could you send me this also?
I'll drop you a PM
Thanks Thumbs Up
Rob 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #523391 31st Jul 2019 9:00am
Popeye
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
I have the adaptive cruise control on my 2012 Westminster. Is a 'nice to have' but would not have chosen it.
I do quite a bit of mixed driving and the ACC is not that good in traffic. I find the minimum gap between the car in front is to big and enables overtakers to jump into the gap, if your not on the ball in cancelling the ACC you end up kissing the steering wheel when the brakes are automatically applied.
It does come into it's own if the motorway is not too crowded but how often is that in the UK???
Post #523406 31st Jul 2019 12:40pm
DrRob
PM sent asking for same Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #523407 31st Jul 2019 12:46pm
DrRob
Agreed. Hardly use it. I do set it to minimal distance as otherwise its too long a range Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #523408 31st Jul 2019 12:47pm
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Hi Greg
Could I have a spec brochure please? Was about to put my own post up asking
About standard specs, so this will be ideal. I don’t have PM ability yet as I’m still too new Smile
Here’s my email: marknash99@gmail.com
Thanks in advance Thumbs Up
Post #533018 3rd Nov 2019 11:23am
Baltic Blue
I only use ACC on mine on the motorway, usually to help get a good DPF regen cycle.
Post #533020 3rd Nov 2019 12:07pm
GGDR
Sent Mark Cheers, Greg
Post #533026 3rd Nov 2019 12:28pm
rvbush wrote:
Most of my travel on business is on motorways, hence the interest in adaptive cruise. Fed up with leaving a sensible gap to the car in front only for some very silly person to fill it and I have to fiddle with the cruise ...
That's exactly why I hate adaptive cruise. Even on its "closest" setting you stand off far enough back for some numpty to fill in and you end up going slower and slower. Unless paying proper attention you never actually catch anyone up to overtake them unless you're an overtaking lane hog. As a result I'm much more often on the accelerator while still supposedly in cruise than I ever was on the standard system. I found that much safer as I'd set the speed I wanted and I just needed to cover the brake in case of numpties or traffic. When you get adaptive, the first time you experience the car standing itself on its nose because it thinks the lorry you're overtaking is in your lane you'll get the idea. Its pants.... Mike - MPx
Post #533043 3rd Nov 2019 1:34pm
Brian Considine
Maybe there is an issue with Mikes adaptive cruise (unless they are all like that).
The adaptive cruise on the DAF's I drive do not re-act in this way, in fact they work very well indeed & can detect that a vehicle that pulls onto your "safe space" is not cause to react straight away. If a cheapscate manufacture like DAF can do it surely JLR can ? 2003 Range Rover Vogue TD6
Post #533065 3rd Nov 2019 7:51pm
